This command enables or disables the configuration of VLAN Authorization-specific settings.
| enable | Enable VLAN Authorization. |
| disable | Disable VLAN Authorization |
N/A.
None.
This example shows how to enable VLAN Authorization:
# configure policy vlanauthorization enable
This command was first available in ExtremeXOS 16.1
